19
→Zylinderkopfdeckel/Nockenwellen MKB AUA, BBY
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | An Karosse
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | M10x35 SV-S16
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 30 Nm + 90°90°
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 906 484 01
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:0.05pt solid #000000;padding:0.097cm;" | 4
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | An Karosse Schraube
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | M10x65
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 55 Nm + 90°90°
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 909 969 01
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:0.05pt solid #000000;padding:0.097cm;" | 6
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Längsträger
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | M8x30
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 23 Nm + 90° 90°
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 0903164
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:0.05pt solid #000000;padding:0.097cm;" | '''3, Ersetzen! '''(muss aber nicht zwingend ab)
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Motorlager
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | SW16, M10x60
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 60 Nm + 90°90°
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 102 121 04
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:0.05pt solid #000000;padding:0.097cm;" | '''3, Ersetzen!'''
SW21
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 90 Nm + 90°90°, geölt einsetzen
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 903 045 06 Vollkopf ohne Scheibe, für Fzg.
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Kurbelwelle
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 12kant SW19
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Vollkopf mit Scheibe,
SW21
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 150 Nm + 180° 180° , geölt einsetzen
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 910 487 01 angebohrter Kopf mit Scheibe, für Fzg.
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Zylinderkopf Schraube außen (lang)
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | Inbus SW6
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | 20 10 Nm + 90°90°, Anzugsreihenfolge Anzugreihenfolge beachten(s.u.), dabei in zwei Stufen anziehen, zuerst einen Durchgang mit 10 Nm vorspannen dann anziehen10Nm, zweiter Durchgang die 90°
| style="border-top:none;border-bottom:0.05pt solid #000000;border-left:0.05pt solid #000000;border-right:none;padding:0.097cm;" | N 10247504
